DBXL !DBXL! shock rebuild !help!
For your shocks fit the DDM HD springs on all 4.
Shock oil...up the viscosity to 6000 CPS silicone diff oil.
Engine requires an alloy mount and shortened clutch case.
I own both a 5T and a DBXL and the shocks are very similar after the above is done, fitting the G320 on the other hand will lead to gearbox and drive shaft failures in the very near future.
FLM drive shafts and alloy gearcases solve that issue and then its much more reliable.
Cheers
Dave :)
Cheers
Dave :)
Thank you Dave
