Im quite surprized that this had to be done .. it is some bad butchering to fit it .. not everyone has resources handy like some of us do .. IMO that a Major R&D failure...
No like I stated previously - I called DDM and talked to Brad. His response was they hadn't seem my version before and suggested to cut off the brace. I haven't talked to anyone from DDM since so I can't say if they plan on trying to create a new pipe to adjust for this version or just expect people to have to make the needed mods in order to make this pipe work.
You're right though, not everyone has the resources to just go out and do this. In fact I don't and that's why I'm not making the braces myself. Most of my wrenching is done right on my kitchen table. My "power tools" include a battery drill and a dremel. Lucky for me RC Solutions has offered to make these braces for me - I lucked out.
-Michael
Chop Suey, good to hear yours installed so quickly - but you're also running the mid-high power pipe where as I'm running the low-mid power pipe. I may end up buying a mid-high pipe as well just to see which one I like better.
-Michael
Chop Suey,
How bout sending me your truck so I can try it out
-Michael
See I take one for the team and test my FG Truck in the most extreme measures so that others know how far to push their trucks and this is the thanks I get... :badair:
-Michael
Im quite surprized that this had to be done .. it is some bad butchering to fit it .. not everyone has resources handy like some of us do .. IMO that a Major R&D failure .. unless it was stated before you bought it ?
but needless to say if your happy im happy :scooter:
RCNUTSHOBBIES,
The pipe Ryan listed above was the top-end pipe, I'm using the low end pipe thus the difference between how it wraps around or goes between the roll cage.
I don't believe this is DDM fault, as Ryan mentioned the design changed in the FG Truck somewhere down the line. If you look closely at the first picture in this thread you'll see the truck they used for the low-end pipe is for sure different then what's out now. The only thing left up for DDM is to create a new pipe that will take this new version into account or just have everyone with this version of the FG Truck do the mods I've mentioned above.
-Michael
...but based on the pictures, they only difference I see from theirs to yours it they did not put the front braces back on the truck or mount the side plate to the gear plate.
