No mistletoe above your tree my friend
i stand to be corrected but im sure thats for 5t v1 and 5b not losi 5t v2The 20 works for 20 and 22 tooth pinon is what I read yesterday
boo that sux loosing an insert would hurtI need to double check, thought I was looking at V2, I lost 1 of mine yesterday after a run had to pull motor, clutch bolts was loose and backed into bell, ordered black 20's
FAT chance of that happeningboo that sux loosing an insert would hurt
Yes You should be able to see the sparkwell losi died on me yesterday after very short run, looks like lost spark, motor wont even pop, pulled and checked mag gap (reset it)
still no spark, order another one from DDM, maybe bye Friday with luck, also fiddlesticked a motor mount screw had to drill head out to get motor off chase, order new clutch mount just in case I screw it up trying to get rest of screw out.
Question:
I should be able to see spark with plug out and grounded to motor when turning fan correct?
or is there better way?
Boo thats no good couple quetions....have you got a kill switch?well losi died on me yesterday after very short run, looks like lost spark, motor wont even pop, pulled and checked mag gap (reset it)
Question:
