Yeah I understand , life ?????Not for a while as I canceled the order? things have been tight with $$$ and after my radio went to ??? thought a new radio and a couple spares is what needed right now??
Just noticed this ? now that I pulled the motor on the bug??View attachment 61197
Leak/seepage on the head gasket?? so it's only a matter of time now until it pops? now Iv gone and canceled my 30.5 motor???
You guys should really be coating your gaskets with some 515 loctite. That will stop 95% of these "blow outs" I typically use it with no gaskets to seal case halves and cylinder to cases.
Didnt build this motor?? it's a 2 bolt and when it pops I'll chuck it ?? and replace with a 4 bolt ??You guys should really be coating your gaskets with some 515 loctite. That will stop 95% of these "blow outs" I typically use it with no gaskets to seal case halves and cylinder to cases.
Done some work on the bug??View attachment 61440View attachment 61441View attachment 61442View attachment 61443
Stuck on a set of new rear turnbuckles?
Real meaty ? 10mm??
Cleaned and re tuned 668 carb?View attachment 61446
All back together ?View attachment 61448
Nice work, I see you brought the wooden hand out of your ass ??Done some work on the bug??View attachment 61440View attachment 61441View attachment 61442View attachment 61443
Real meaty ? 10mm??
Knew the hand would get some hits???Nice work, I see you brought the wooden hand out of your ass ??
Doug likes it sloppy ???Could have at least washed it first ?
