True. Would be nice but you can't have everything right lolYip all spins fine ?? would have been nice as a new complete. Just build a new complete without stripping the old one???
No you can I'm just not rich enogh???????True. Would be nice but you can't have everything right lol
Yip coz any less than 5 lbs just won't do?????Hey z if you send Doug presents make sure you mark it as a care package ? then customs shouldn't charge him a terrif. And it will look less suspicious when your sending him 5 lbs of smoked sausage ????
yip it could just disintegrateWhat's the worst that's gonna happen? The boot flys apart ?
Awesome ?I'm gonna see If I can strip my diff and rebuild it this morning ?? get rear end mounted on my new chassis??
I've done that mod on my rigs doug, you can also use a boot for the throttle arm on the carb, I'm not sure how effective it is but it looks good??So I could not help ? myself started stripping down the rear end to get at the tranny gears??
View attachment 52263View attachment 52264View attachment 52265
The bearing on the lay shaft was done for
I was sure there was supposed to a dust
Cover there in the stock setup??
So I have made a plan I saw online .....
Not sure how it will play out guess time will tell
Well TR diff case saver makes me sticky becuase it goes together instead of 3 hours of bullshit. Wasn't worth saving money lolThe diff saver case was a bit sticky? went under the ring and was catching a bit ? but in the end it went together??
Was not cheap but?? quick diff case $130 saver case and diff $79???Well TR diff case saver makes me sticky becuase it goes together instead of 3 hours of bullshit. Wasn't worth saving money lol
