Duratrax Bandito on road tires.
Thread starter #1
Likes
2
Richmond BC Canada
I was wondering if anyone has had any experience running these tires,
https://www.amainhobbies.com/duratrax-bandito-b5-tire-front-2-dtxc5002/p642711
I have a Losi B and looking to run it on pavement a bit, the area we run is not very clean and dry right now so I don't know if a set of slicks(Hostiles) would work very well so was thinking of something with tread, or maybe a set of HPI Tarmacs or Madmaxs? Any other suggestions would be appreciated..
Thank you,
James..
dougstar
Likes
1,842
KZN South Africa
Hey welcome the forum @Jimmyb the duratrax tires look mint never run them though:unsure: like the lockups:love:
Not what you looking for. Madmax are great but their beadlocks are not the right shape for losi. They damage tire rod ends and rear hubs were the rod ends attach(n) buy silverback or ddm inner beadlock rings if you go for the madmax
Thread starter #4
Likes
2
Richmond BC Canada
Thank you dougstar and Seandonato73, I am just getting back into 1/5 scale after selling off my Baja 5BSS years ago, friend got me hooked again. I tried to find some reviews on the DuraTrax tires, they produce them for 1/10,1/8 and the 1/5 scale but couldn't find really anything. I think I will order a set and try them out. Price isn't too bad but our Canuck buck sucks. I have few sets of BAJA 5B rims left over, I recall reading and as dougstar mentioned clearance issues on the rear with the wider rear rim/tire of the BAJA when installed on the LOSI, they clear when static but rub when running, would running the BAJA fronts all the way around still have problems or just get wideners and run narrow fronts and wide rear, would the Silverback or DDM beadlocks provide enough clearance on the BAJA rims without wideners? I think these are a bit smaller in diameter(10mm,3/8") but can always try different gearing . The Madmaxs seem to recommend for warm or hot applications so do not think they would work very well until late spring here..
Thanks,
James..
Seandonato73
Likes
953
I would personally get another set of losi wheels and put the new tires on them. I have a dbxl so I cant say to clearance issues. I also run extended hubs. I do however have hpi baja size tires on it. The fronts are the size you would be looking for. The rears may give you clearance issues.
Scruffy
Likes
353
I personally would not buy another set of duratrax tires. They are rediculously soft and don't hold up long. I had a set of duratrax sixpacks on my baja and ripped the side out of one of the rears on a small stick👎
Nasim
Likes
45
I have a dbxl with extended hubs and rear Baja wheels on all 4 corners running Duratrax Six Pack b5 tires. No issues here.
