I don't know if anyone is interested anymore but I made a little progress and figured I would do a quick update.
After extensive modifications and some custom fabrication to the FG F1 Competition, I am about 50% through the conversion. Still need to make overhead support braces (to restore rigidity), new brake servo relocate/mount and there’s still the sizeable capacitor pack, receiver &
BEC. I also need to paint the body, drill, countersink and slot the pan for the new set-up, lots of soldering, program everything and do a final assembly. And make a video for prosperity - lol.
What has been done is:
Cut and machined the chassis spars (vertical supports) to accommodate the conversion
Extensive re-design of the steering servo and anti-roll mechanics. Also made a steering servo mount and drilled/tapped and contoured the front chassis spars and various other mods and extensions to get everything to ‘clear’ including elevating the whole steering pinion on a custom spacer
Machined an ESC mount - G-11/FR-5 GLASS EPOXY COMPOSITE. It’s nonconductive, very strong and temperature resistant. It destroys carbide end mills though LOL. Truly tougher on cutting end mills and inserts than high carbon steel alloys and titanium
Additional machining to the motor mount
Made battery brackets
Some fine grinding of the gears so the whole drive train spins effortlessly
I feel there’s a few more things but I can’t think of them. With the ESC and motor it has a pair of 7S 6500mAh MaxAmps LiPos. Also a Western Robotics Hercules Super
BEC and a Futaba R334SBS receiver. With stock tires and gearing (5.333:1), the 5 wind motor and 14S power, the theoretical top speed is 126mph.
