Engine probs
Lol guys, its more than that, fuel all over the carb... im not a noob
Look little dude you didn't say what you did for trouble shooting. So you got the f'ing basics kid. If you have fuel going everywhere then obviously you have some gaskets leaking or something. Carb intakes probably loose. And I would say you are still a noob if you are asking questions like this and giving us crap because of your lack of info given to us in the first place.
order a rebuild kit for your carb and start there. also clean the carb of all debris so your not adding to your issue, most likely you have a worn out gasket or seal and its allowing air into your carb .
Yeah freshly clean, yeah the choke was off
just a thought, and its an easy mistake to do mate,
but you say freshly clean filter, do you mean you cleaned and re oiled it ?
if so then possibly over oiled the filter :),
and if the insulator is loose in any way ( you said above it was slightly loose) then its gonna suck air at some point between cold and hot (y),
If the insulator was too lose it wouldnt have fuel everywhere, the carb need the pulse to pump fuel. Prime it till your blue in the face and it wont put a hardly any fuel out with out the pulse line hooked up.
Back to baby steps. Did you check and make sure your needles are set to factory?
And did you try starting it with out the filter on?
And clean that filthy pig boy, you don't want it leaking on your parents Persian rug.
