josegarcia8578
- San Diego, CA
Hi all,
I purchased the outweras flywheel cover as well as the pull start cover, the install requires engine removal. Anything I should be aware of when removing he engine from the losi 2.0? Do I need to worry about the gear mesh? Or is that set by the fastener inserts?
I'm asking because the first time I removed a big block engine, I had a lot of rookie mistakes, such as not knowing about gear mesh, etc. I want to be able to remove and reinstall the engine without messing anything up. Tips?
