Engine shroud breathable cover outerwear
It seems like a great concept, but there is engine heat that need cooling and the carb needs to breath. You can seal the holes around the body through sheet metal fabrication like I did. simple is better, just a little more work
if you really want to get trick, but aluminum window screen , cut to fit the bottom of the engine case and JP weld it in place. it works very well
Its breathable material though
And by looking at the second picture you can see the side with the gas cap is open so you would still need ps and air filter pre-filters. It does look like it would keep the inside of your rig a lot cleaner tho
