Instead of buying separate outerwears for the PS and filter, has anybody simpy just used this to cover the entire thing? http://www.tgndistributing.com/baja-5t-sc-pre-filter-shroud.html
It seems like a great concept, but there is engine heat that need cooling and the carb needs to breath. You can seal the holes around the body through sheet metal fabrication like I did. simple is better, just a little more work
