Engine Temps
jkoppk
Mcsherrystown pa.
What are normal engine running temps and from where on the engine are you checking it?I saw somewhere 500f at base of plug is mac before damage,is this true?
I had these types of engines smoking hot ,they can take a lot of heat! ,been working on them for all most 30 years!
I was asking about temps because on another forum someone posted a email reply from the engine maker and they said keep under 482F Max measured on the case at the base of the spark plug.
That is a lot of heat ,an can be generated even with a shroud over the engine ,if the engine does generate that kind of heat ,I would
defenitly monitor temps an if an engine does get close to that range ,I would clear any thing out that blocks air flow!
