tizdaz
hi guys, i have a zen g290 and a carb i taken off a G320 which is brand new pretty much, ive reset the needles to L:1.5turns & H: 2turns
Ive not long rebuilt my FG and decided to throw in this zen 290 thats been sitting in my box for around 5years! (was working last time i used it!).. Anyway i fit the new carb & Primed it, then after 1 or 2 pulls it started then died after about 1 or 2 secs.... since then its been a bugger to start... but same thing, will start for a second then die. Ive flooded it a couple of times by over chocking it etc trying to start it, but its easy fix (spark plug out tip upside down etc!!) But then i will try again, it trys to start but then goes dead, i was literally trying for around an hour then gave up on the pile o sh!t!
Checked all the usual things... fuel lines are new, carb is getting fuel, plug sparks etc
Also tried various carb settings, no joy. I have a new piston ring & gaskets, would a worn piston stop it from starting, would this give the result im getting where it will start then die pretty much after 1 or 2 sec?
I have a feeling its this poopy carb to be honest as im sure its the one i taken off my zeng320 when i had issues starting that engine! i may have a look if i have a 990 or 813 lying around and try that! ...any suggestions
Like i say, the first try... it started for around 3-4 secs, then died.. since that, its been a nightmare to start, and when it does it barely for a second, then dies. Also i was getting like a backfire sound sometimes when trying to start it!?
Cheers!
Cheers!
