Hey Rep732.. I did receive my esp kit.. but theres no instruction about the case mods.. Only tuning instructions..There will be instructions in the box to tell you where to grind. I believe I got away with not having to grind my cases to fit the stroker crank, your basically making room for the bottom of the rod not to hit the case
How on earth would you grind the case with out splitting it? Need to remove the stock crank for the new one anyway = splitting the case.
Thank you guys for the help.. But luckily theres no need to grind the cases for clearance.. the new crank fits as it is..
Using a stock Zenoah G320..Not exactly sure on your combonation so maybe what I am asking does not apply.
Does the connecting rod clear the block as well? I know on a lot of the stroker stuff I do ( automobile application ) the crank itself clears no problem. The problem is the rods hit the pan rail once installed on the crank.
Just be sure that the big end of the rod clears as well.
Hey guys.. Finally started the engine.. Sounds great but theres one problem!!
It idles great but while giving throttle input.. It bogs for half a second and then pulls well.. What could it be??
My thoughts too. Open up the Low needle a bit.Sounds like it is looking for fuel. Give it a little extra.
Maybe start with 1/8 turn out.
Agreed. I always run them fat to begin with even after my extensive break-in process. I like to sneak up on a crisp, full power tune. LolI should have mentioned low.
This whole kit is larger displacement wise so watch it doesn't go lean on the top end as well.
In theory a bigger displacement engine will use more fuel.
Myself, I would probably fatten them both up and then tune from there.
At least it should be safe a little on the rich side; at least for starters.
Yehh.. it feels like it’s bogging after the initial pick up..One full circle , sounds like a lot of fuel.
Just guessing and every application is different so maybe I am wrong but it doesn't sound right?
Could it also be too rich??Yehh.. it feels like it’s bogging after the initial pick up..
Sure it could.Yehh.. it feels like it’s bogging after the initial pick up..
Thanks mate.. Will give it a shot and keep you posted!!Sure it could.
Try going in maybe 1/8 turn at a time.
Make a pass and " listen " to it.
In another 1/8 and try again.
Sneak up on it a little at a time.
Don't make multiple changes at the same time.
Baby steps and use your ears!
