CraigRobbo
- Salford, Manchester, UK
Looks slick mate, can you get a piccie up of all 4 on please ?Ok I just measured with a tape the track width is with just the adapters 9mm a side less so overall 18mm, with the 9mm square your back to the same track as using the standard 14mm square.
sorry picture is crap but you can just make out the difference, the fg wheel is mounted on a 17mm square (what i usually use front and rear) so imagine 3mm less on that side. Paddle side is with just the ramtech adapter
and 9mm square spacer
