My FG 4WD Sportline just locked up and would not move. So I Took it back home and disassembled. Nothings wrong with the clutch. I could not push it and it would not roll freely. Took the diffs out and looked at them nothing wrong that i could see but when i tried to move the gears with my fingers they would not seem to budge. The front diff moved a little bit but still hard to move. Ive rebuilt quite a few diffs but they were sealed diffs for 10th scale vehicles and the gears pop right in and move freely as they should. This seems to be something quite *diff*erent (pun intended). i managed to get the gears out to inspect them and theres nothing wrong with them. no damage or anything. I cleaned them up since i already had them out thinking it would be a breeze just to pop the gears back in and grease them up a bit. Was I in for a surprise. These things are a beast to try to get back in. Added to that the gear teeth are sharp and hard.
I tried couple different techniques. I tried somehow to hold all 4 gears aligned in a perfect square (impossible) to try to slide them all into the plastic diff housing all at once but no dice. One always seems to move out of alignlment which throws the others off. Then I tried assembling it by adding one gear at a time which was fine until that fourth and last gear. Impossible to fit in there. Im not sure how this thing was assembled. Pluto has to be aligned with Mars it seems for this thing to go in. Now Ive got the car dissambled not knowing how to get the diffs reassembled to put the car back together.
If anyone can help or someone might know of a way or some trick to get this thing back together.
Any help would be greatly appreciated.
Thanks
Thanks
