The people you spoke to may absolutely be right about the WD40. Most of the bearings are sheilded so its highly unlikely that they will get any sand in them. i was talking about using it more as a rust preventative then an actual lube. I suppose a white lithium grease would work if your worried about the WD40 washing the grease out of the bearings. they have the WL grease in a spray can at most auto parts places. The baja does just fine in the sand with the stock tires, packed or loose sand. It probably wouldnt be worth the extra money to buy the sand paddles if you were going to run only a couple times a year on the sand. I do like the way it drives in the sand with the paddles, the rear tires get so much traction, its awesome to see the 20 foot roost kicked up by the paddles. they do tend to make the buggy wanna go straight through a corner though, the buggy will actually slide around a corner better with the dirt spikes. the outerwears pull start cover i don't think is a needed item. I just pull my starter off occasionally and clean and oil it. the dirt and grass entering the pull start cover is not really going to do any damage to the engine. the problem is with the vents on the bottom of the engine, if you get a stone in there it could take out your flywheel. ive seen them pull in stones large enough to stop the engine and wedge between the flywheel and flywheel cover or get hung behind the flywheel. the ripping tires is a issue with the tire itself, the beadlocks i don't think are causing the rips. it simply just too soft a compound. M or H compound for the rear would be a better choice but they do not make them in those compounds only the S. just incase youre wondering S soft M medium H hard. probably figured it out though. i have not had an issue with a torn tire yet, my cousin however is on his 5th pair of rear tires. He drives alot harder than i do. if you keep it from pitching sideways off a jump and landing directly on the sidewalls of the tire you should be ok, and avoid the powerslides in shell driveways.
