Finally got some pictures on my rocket on my baja.
supk0be101
North Hollywood, CA
I put that piece of brick in the front so the rocket does not push it anywhere.
These are the pics that I have. I also have a video demonstrating the rocket in the back. Check it out at youtube with this link:
Thanks for watching. If anyone needs help with their baja, pm me.
How far forward will it go without the brick and without
the engine running ?
Will it work with a killswitch installed too! as id rather not
get rid of that lol
get rid of that lol
You need a seperate channel for the rocket system. But I have a way to make it work. I have a 3 channel spektrum radio right? But my spektrum DX3R can bind up to 50 recievers. So, I just put 2 spektrum recievers in my baja, and bam, i have 6 channels. I just switch to the other reciever to turn on my lights and my nos system, and all that extra stuff, then I switch back to my main reciever and do everything else. :lol:
As far as I can see from the video this is only a model rocket engine.
I have buildt my share of these rockets, and I would say that without the brick, the Baja would still not move. When we build rockets for these motors we build it very light, and the baja are around 10-15kg? Forget it! Visual effect? Great! Boost? Now Way!!
http://www.321rockets.com/e9-6-estes-rocket-motors-1674
Engine Type: E9-6
Total Impulse - N-sec: 30.0
Time Delay - Sec.:6
Maximum Lift Wt. - Oz.: 12.0
Maximum Lift Wt. - g: 340
Maximum Thrust - Newtons: 25.0
Maximum Thrust - Lbs.: 5.6
Thrust Duration - Sec.: 2.8
Initial Weight - Oz.: 2.00
Initial Weight - g: 56.7
Propellant Weight - Oz.: 1.27
Propellant Weight - g: 35.80
you beat me to it,,talking about large out put rockets to mount on these, and with some baja's as heavy as 35-40lbs i highly dought without the baja engine aiding the rocket motor, that baja is not going anywhere,
more for show,
what i haven't seen and would like to see is the actual mounting of it, hows is it mounted to the baja? what type of rocket motors are you using? and a actual video of it moving the baja and the boosting it does, the ebay posting does not even state or picture what your getting for what a $199 starting bid?
sounds a bit far fetched
Thats why ive asked him how far will it go without the brick and
without the engine !
If the is no boost whats the point ? don't get me wrong it looks
great!
I was intrested in this but if its just for show im out...
well i'm like any gear head, looking to get more speed torque, of course bling and anything else i can put or get out of my r/c's,but this just seems a bit ridculous
Engine Type: E9-6
Time Delay - Sec.:6
He says in the video that this is the engine he is using.
The numbers speaks for itself :lol:
