So before I just trash this key in the crank HAS anyone removed one that is stuck tight in the crank? My options is grind it flush so it can pass through the bearing. Heat up the crank as the seals will be replaced anyway. Cut the feking thing off as the crank is garbage. Trying to save the case thats all that matters
