renbar
maybe time for a change in hobby have you looked into lego
thanks
i found this video but its not show me how remove or what stuck the engine
Everyone gets a stiff one from time to time.
Sometimes a bit of lubrication will help before wrenching.
Sometimes hitting it might loosen it a bit.
Al.
hi mate i have a smartech spider basically the same as the uno and they all leak fuel from the breather all of them ! its a common fault with the smartechs what you need to do is change it for a fg marder one and make sure you get the strap with it to mount it to your car as you will need it ! they are cheap on ebay and fit straight in and no more leaks !
The same problem i have with my Smartech tank so this kit to orderYes that's the correct tank mate !I think more of us should even suggest to them to change the tank as it would probably cost them the same to put the better tank in !
https://www.fg-onlineshop.de/ItemDe...=25&ig1id=26&iid=1575&mi=0&hasv=0&webi=0&pr=0
just to replace the old one and connect the pipes?
Thanks
