General question: G320 vs G290
enzo3856
So earlier I was considering if I needed a new engine or not...
I was looking at a Zen for reliability and quality.
DDM has the 290 and 320 longblocks, just $10 difference....
So a couple questions for my education...
Aside from displacement, whats the real difference between these 2 motors?
From my position, I have a baja with a CY26cc, and I have changed enough things to make it reliable, running standard gearing (57,17 - i think)...
If I wanted to get one of these long blocks and not change much else, which one would be the better choice and why?
Just make sure to get good tires as you will spin more with the 32 . It also depends on your use. For offroad I think the 32 will be the way to go. For on road , 30.5 and even less (29, 26cc) are better ,as they spin more rpm and have less torque (so you wont be spinning out every second)
Yep solid engines specially with the esp ported/ stroked.
Might try the same combo with the high rev piston on the new losi 5t that I got.
Sure man. I spoke to Doug and he said it is recommended to run 100 octane but I am running 110 anyways for the vekta so shouldn't be a problem.
