Having carb issues
@javi83 I forgot you mentioned what to upgrade the air filter to. Get the dt-1 triple foam filter and order the ddm 3/4" velocity stack
Does that setup clear the cage or would some trimming need to happen? is there other v Stacks that work too? Since it’s out of stock.
@javi83 it clears the cage no problem. Also to mention a 1 inch stack won't be an issue as far as clearance, it's just going to sit a quarter inch deeper into the filter. I do absolutely recommend getting m5x55mm or m5x60mm carb bolts if you go with the obr billet insulator.
Here it is installed on my 5ive-t
I did end up getting the insulator will be arriving tomorrow those bolts you say are shorter or longer ? I haven’t seen a stock one next to the obr so I don’t know
Yes they are ill link you to them from ddm. The stock bolts have roughly 3 threads of engagement left after the insulator stack you need to assemble. The m5x55mm gives you about 5-6mm of thread to sink into the aluminum portion of the insulator (if using a 3/4 velocity stack) which is good, if using a 1" velocity stack id use m5x60mm.Don't forget to use blue loctite and make sure you apply the loctite after you stacked the gaskets so the loctite doesn't get between the gaskets and mating surface. Also you can eliminate that spacer between the carb and stock air filter as you'll have enough clearance between the carb and stack as the m5x60mm will not accommodate that being there.
https://www.ddmracing.com/carburetor-bolt-set-m5x60
