Thunderbird1983
- Reaction score
- 1
I want to go through diffs on KingMotor X2 and im not sure what weight diff fluid to put in front,center and rear.
Thanks i will now order correct fluidsLosi stock diff fluids
Front: 7,000.
Center: 5,000.
Rear: 2,000.
Stock set-up sheet is below.
Mine had movement like that stock as long as there is no side to side movement. If your going to be racing you should look the Modified RC Center Diff it used bigger bearings and is a big improvement.MGP—— I’m racing this truck i ran it yesterday and i found a little movement on the center differential. The outdrive on the front of the case that attaches to the front driveshaft has a slight movement in and out when i grab the cup. I can slid it out a slight bit and then slid it back into the case i would say maybe 2mm or so. I believe there’s a pin inside diff. holding the outdrive cup. Or maybe the bearing failed. Not sure?
make that a obr 34 v2 reed now..I run 30k-100k-15k....f-c-r......but i run a full mod 30.5......![]()
Same HereIm running stock diff fluid on my losi 5b
Front 10k
Center 15k
Rear 5k
100k center diffmake that a obr 34 v2 reed now....on the same diff oils..runs sweet as still.
its now 500k....100k center diffmay as well have a diff lock
I don't know y I didn't have them in.....should have put the gears in first.
LololI don't know y I didn't have them in.....![]()
It was because i wanted to get the oil in to all the lower gaps bevore i put the gears inas it was mega thickmaby you just forgot.
