Apologies if this has been previously discussed but I’ve attempted searching this and haven’t had much luck. I am swapping out a 30 cc fuelie with a G320 RC. When I went to bolt the engine to the chassis plate I found the Zenoah engine mounts are approximately 1/8 to 1/4 wider apart.
Has anyone else come across this, or am I doing something wrong?I am hoping I can just switch out the fan shroud, if that will work? I’d prefer not to have to modify the chassis and do some garbage job of elongating the factory holes to make it work.
