Just Fishing
- Reaction score
- 77
https://www.ebay.com/itm/1-5-King-M...Kit-Fits-KM-HPI-Baja-5B-5T-Rovan/352474831019
Tearing up my culdesac, just having rear brakes is not great.
I read that these things are gimmicks , but figured wth.
First let me say that the instructions were... lol
pictures, pretty vague pictures.
They have you install the brake pads backwards...
They are even backwards in the ebay ad!
it was best guess to even figure out how the fk i was supposed to mount the brakes to the hub.
Then the best part, in the instructions it shows an image of an extended axle!
lol!
so when you install them with standard axles, the brakes would bind and the wheels won't spin...
i ended up taking off a bit of material,
sorry this was not planned out well, but red marks from the ebay ad show material i had to remove...
If anyone ever got this set, i could show more.
but it's a bit of material, the aluminum part is easy/soft.
but the piston that presses out on the brake pad is steel, and it needs to be ground flat.
Here it is installed on my rc.
Anyways, what a joke that was, i wanted to share.
I still need to work out the rigging.
their half baked plan was to replace the throttle/brake linkage with one that's not even threaded on the end. :lol:
Just so you can install it on the other side of the fkn servo.
then to install the front brakes on the original side, meaning i would need to reverse the servo function...
I'm working out something different.
just silly!
lol!
just silly!
