- The Rock QLD Aus
I'd be looking for a 4 bolt long block.
2 bolt heads are notorious for blowing gaskets.
That sucks. I just have had this one season, bought it used last March. Always ran 25:1 and never leaned it out. My needles were pretty close to stock.Dammnn... and by the looks of the top of the piston being so clean you had detonation with all those divets in the piston and were very lean. Seeing how that piston looks that top end is trashed
This happened on my other baja. The Baja from the original post is running fine. New carb is working great.Yep agree with phill 100%. 4 bolt long block time. You can tear it all apart and lap the cylinder and case to get them mated all nice and flat, but inevitably it will blow another. I'd bet this was the original carb issue. Air leak.
Nah sanding board, file and straight edge is all that's really needed. We'll a sharpie or Prussian blue would help too. But nothing too terrible to finish off the season then think of getting something else.Lapping the cylinder and crankcase is a good idea but I'd be looking at the price of getting that done as opposed to a 4 bolt.
Come now phill, it used to be standard procedure to belt surface heads in automotive and Industrial applications. Biggest down side was the cost of the belts and training people to set the machine up right. Surface finish wad the next "issue but largely negated by proper grit and belt make up. You'd be surprised how flat you can get something with a piece of glass and some sand paper. Let alone a good file and something to indicate low spots. Remember the best machine beds were hand checked for flatness and corrected by hand. We've gotten lazy in the last 10 to 15 years, and made machines to make machines. It's one little cylinder and case. Take about an hour or so to true up. I do agree to be on the look out for a 4 bolt, but no reason to toss something thats easily fixed.
Amazon, eBay not hard to get dykem makes it.Very true Sean but why waste the time on it?
We used to use Blue as an indicator but I wouldn't even know where to find it these days.
Thanks for all the guidance folks!Amazon, eBay not hard to get dykem makes it.
Idk I look at it this way, he'll have all of $40.00 or so into fixing it to get going again. $200.00 ish for a long block, finish out the sumer with it and replace the turd over the off season. He gets a little more familiar with his rigs engine and is really non worse off. Now if the cylinder was trash then yeah I can see just replacing it.
yea4) If I get the 29cc Zenoah long block, will my cy26 bits finish it off? is it compatible? (flywheel, clutch housing, etc)
I don't have calipers or know anyone who does...No no 5mm.
Squish needs checked before you go and buy anything. All you need is some solder and a calipers to measure the solder.
Place the solder inline with the wrist pin (use a bit of grease to hold it. Lead solder works best for this) bolt the head on with out the gasket. Turn the engine over and squish the solder to get the clearance. Pop the head off and measure what you got. Get the gasket that gets you closest to .020" of your way over .020" to begin with then get the thinnest gasket and use that. I think it's. 005".
they are cheapI don't have calipers or know anyone who does...
You'll find them.very handy in this hobbyI don't have calipers or know anyone who does...
Actually Amazon has a caliper for $18... next day delivery too...
I am sorry, the last part is not clear to me....No no 5mm.
