- Queens
I searched the forum for some info, and all I found was a funny argument with Z and some other guy . Anyways, are they any good/better than regular? And what is the difference between the two in DDM dotd?
Tia
Tia
You like when it sticks out huhi tried iridium plugs in my twin,
it ran better on normal cmr7h ones,
plus the ceramic on the equivalent iridium to cmr is taller, so plug sticks out in the open more ,
So they're all the same then, only difference is price?Spark plug is spark plug
Spark plug go pshhhSo they're all the same then, only difference is price?
Great nugget of information there, got any more?
Don’t understand what you’re saying.Spark plug go pshhh
Ehh its a stupid memeDon’t understand what you’re saying.
Ah damn. See im still learning. In all seriousness. Your standard NGK spark plug is all you need for any 5th scale engine. Anything else is just try hard.Blow off valve on TURBO car go psshh... spark plug go bzzzapp....
Well you did it wrong your supposed to touch the plug with your tongue while the engine is running to make sure you have proper spark discharge...Oh poopy plug. Can't be worse then rovan one that discharges through the shielding into my hand every time I touch it. I've literally killed my engine by touching the spark wire.
