Here is a picture of the manual and there is no shims or blocks in them.dude, do you have a pic of what came outa yer diff ?
its not really possible for that to happen with how the diff internals are fitted mate,
all internal gears are shimmed anyways,
heres a link to what should be in yer diff,
https://www.rcmodelz.co.uk/spare-pa...arts/losi-dbxl-diff-rebuild-kit-1-dbxl-e.html
That is correct!! I ordered the rebuild kit and it came with the blocks..Look at the cup better. It doesn’t look like the square support blocks could fit in there.
is yours just a bbxl or a dbxl-e or 2.0 mate?That is correct!! I ordered the rebuild kit and it came with the blocks..
could you refit your old stuff loose in the case and take a pic of the cross gears and post on here mate ?
sommat don't seem right tbh,
i have a dragon hammer which uses basically the same parts as a dbxl on the diffs, and i'm pretty sure it has the squares fitted,
cant be 100% sure on that cos havnt had the diffs apart for a while though,
as clubin said above mate, there should be at least steel shims behind the gears,I have the Dbxl 2.0 gas. Here is a picture of all the pieces that came out of it and there are no shimsView attachment 82460
Yeah I was a little confused when my parts came and the squares came with it, but don't show them in the manual along with any shims.as clubin said above mate, there should be at least steel shims behind the gears,
but this is very strange, every rebuild kit i can find for the dbxl/dbxl-e/dbxl 2.0 and dragon hammer comes with the squares as well,
and there ya can see the issue, the smaller gears aint even meshed, that should have squares fitted dude,
I put the parts in them. Those where all the stock parts that came in stock cups. No shims or blocks either. The stock cups or the hot racing ones have the cut out for the blocks to slide into.gavsta hit it on the head mate,
as said above, someones just fitted the stock parts into hot racing cases without fitting the extra bits (squares and shims),
you can see the gears aint meshed at all how yours is set up,
if you have hot racing cases on all three diffs i suggest you strip em all and see whats inside,
so from what gavsta said above and in the link he posted the hot racing cups/cases should have come with the blocks and shims as part of the sale if bought new mate,I put the parts in them. Those where all the stock parts that came in stock cups. No shims or blocks either. The stock cups or the hot racing ones have the cut out for the blocks to slide into.
Sorry but this should have said that the stock or the hot racing don't have the cut outs for the blocks to slide into.I put the parts in them. Those where all the stock parts that came in stock cups. No shims or blocks either. The stock cups or the hot racing ones have the cut out for the blocks to slide into.
