Renbar, on your front and rear upper wishbones you should have some 25mm studs for raising and lowering ride height
http://www.fg-modellsport-gmbh.de/_PDF-ANLEITUNGEN/E.06000-01.pdf
if you look at the FG diagram, the studs are part no. 6101
if you locate them on your car you will see the lugs they rest against and by winding them in you will lower the ride height
hope this helps
