Walbro 1107, when cold, choke and 3 soft pulls and it sounds like it’s ready. Choke off I just pull it but not like an animal.What carb are you using and can you explain the technique you use to start it?
I have 3 of them I have been swapping with. If it gets wet I spray it with carb cleaner and grab the next dry oneIt could be overly flooded. I had that happen and it took me days to get it running again. Flip the truck over and remove the spark plug then pull on the pullstart and see if fuel comes dumping out. Your gunna need a new plug or dry the wet one really good
Yea no kidding. On my first (and only) nitro, I didn’t have any troubles tuning and getting it started.Hopefully you won't continue to have issues and enjoy driving it.
I will have to try this.Yes fill the line maybe half of the length, use maybe 8"-10" of fuel line. Take the metering cover off and the diaphragm. Now just watch for air bubbles or for it to pop off.
