- Thread starter
- #101
I thought it was at first tooAppears to be a roller bearing to either the wrist pin bearing or the crank side rod bearing. Or a locating Dowel, internal or external did you find it?
Yep I figured. I did try it and had the same results, fearlessRC told me to send it back so they can look at it. I have the engine out of the truck right now, I just have some parts to remove from it first. We will see what happens.By rtv, he means moto seal, yamabond three bond, dirko ht etc. Something that won't break down with the gas and oil.
I'm glad you posted this. Mine started acting the fool today. Chasing the tune. Had to keep richening the high needle. I pulled the body off and while it was idling to cool down I hit it with some air to blow off the grass n dust. Soon as I hit the intake area it almost quit then immediately recovered. I repeated it and it did it again. Intake warping with only5-6 tanks of running. New aluminum set up from DDM on the way.@Dirty30J the issue with the plastic version is it will warp. Your putting a bandaid on a situation and eventually it will come back but this time it will be in the form of an air leak.
https://www.ddmracing.com/zenoah-585727001-g320rc-insulator-manifold-billet-aluminum-ddm@jeepfreak1972 I didn't like the ddm one at all with the thin nylon insulators. Get the one from obr and you'll never have to worry again
Well shoot...@jeepfreak1972 I had v1 but those insulators seemed to never let the bolts get tight without starting to squish the nylon. The obr one has a thicker insulator and the bolts feel more secure when torqued and they don't ever loosen
Damnit!! LolThe obr one is awesome, super thick compared to most all of them
I'll order the obr and send back the ddm@jeepfreak1972 the ddm one is just no good, they really should be using gaskets along with some sort of composite like delrin or nylon. I too tried using what was included when I first started out here and it wiped out one of my engines. Spoke to ddm and i got a top end out of the deal. Obr is gasket to head then billet insulator block then gasket then delrin piece then gasket then carb.
I'd be pissed if I smoked my engine. Even if it's currently stock. In fact I thought I did today. It just quit at full throttle. Turns out the rubber switch cover, on the receiver on / off switch, is pushing the switch slightly towards off, activating the dynamite kill switch. It does it in bumpy terrain some times. I'll have to take it apart and get more room for the switch to move inside the rubber cover.Good choice![]()
