BIGDADDYSHIMMY
- Roanoke, VA
Just received my KMX2 i purchased from the dealer in New York using the website. Was nervous about a off branded version of the 5ive but after a full teardown and reassembly I am quite impressed with the quality. Took me and a friend about 6 hours.
After checking off all the issues that were mentioned frequently online I was impressed to say only the center diff fluid was sub par in viscosity but not leaking. Front and rear diffs were tight. Shocks were full with smooth bores and I chose not to resize piston holes for now. Viscosity of fluid unknown. Included receiver battery was a NiCd or NiMh that I will be replacing. All metal on metal screws were loctited properly. The C hub retaining pin set screws were not fully set and the swaybar set screws were also not fully tightened. The included hop up aluminum parts fit and look great. I purchased the upgraded shock towers with the kit and they fit well except for the clearance on the rear shocks. The shock cap interferes with the recessed milling on the shock tower unless you move washer from front of shock tower to just behind rubber shock isolator on the opposing side. Pics would help but alas its 50lbs of awesome I cant lug into work.
If weather holds I will commence break in procedures this evening. The neighbors will love me!
As I said to my helper last night it looks good so far but the proof is in the pudding. Exact phrasing was "It could still be a colossal turd once it hits the dirt." :w00t:
