is thedominatorpipe better than the tuned pipe from king motor
Yes, The size difference does make the tune different.
what is the fuel mix ratio for the KM 29cc
If your talking gas to oil then between 25:1-30:1.
i did some checking before i purchased a buggy,KM looked idenicle to HPI on the outside, so i took a chance, and went the cheep way out. $500 vs $800+ for a SS. "bad mistake", out of the box throttle horn was broke, no biggie, futaba horn fit perfect, no time steering servo stripped, KM servo bracket different from HPI, replaced with HPI bracket & servo, although diff looks strong enough, it's not the same,"outdrive cup shafts are smaller diameter", spider gears look the same as HPI, all bearings are good quality, although engine looks to be same as CY, it isnt!!! ran strong for about a half gallon then lost all compression, tore down, stroke is longer than CY, clutch housing is integral with crankcase, "not removable" --shock internals are different (although i do like their design) plan on changing fluid right off. after about 2 grand of repairs & upgrades i finally have a good racer!!! IMO buy a HPI ss, (wish i would have)
Any photos?
Hello,
Will the Baja Aluminum Tuned Pipe for the 5B SS HPI fit my King Motor Baja??
Also what HPI Baja version is compatible with the King motor Baja??
