Hey Guys,
As mentioned in another post, I've had some bad luck with the clutch on the new KM I got this weekend.
The new issue though is with the HPI clutch and spring kit, 6000 rpm.
It's creating massive clutch drag, so much so that if I try to slow the truck down or try to stop the tires from spinning it stalls. I am sure it's the clutch that is sticking because I cannot even start it without the tires on the ground.
I opened the clutch up again to double check, and everything looks fine. The shoes are not sticking (at least when the engine is off) and I can even free-hand the clutch bell...spins nicely.
I got it back together again after verifying everything in the clutch is fine, but it's dragging again
Truck is not useable until I figure this one out. BooURNS!
That said, my KM did come with the 8000rpm clutch setup. My LHS didn't have any in stock so sold me the 6000.
Is this a known issue? Would changing the spring to my king motor 8000 red spring with the new shoes show better results?
Could it be a compatibility issue with the KM and the HPI parts?
Suggestions would be greatly appreciated!
