Kv5 TT TRC 65
Braap2smoke
Bay Area,California
what are you guys using to keep the exhaust flange from backing out? I seem to keep having this issue even with red loctite. Are there different style nuts to use?
I used blue loctite and gave it 2 days to cure no issues on my 65 and 50
You can try a longer bolt and use a second nut. I also seen people drill a hole for a pin behind the nut
Thx for the replies. Im gonna try to dig into it tonight and see if it was the nut or the stud.
On a side note my vekta 5 with obr 32 has a turtle racing clutch in it and so far not a good experience with it. Ive used loctite per the instructions and it seems to always back out. Im gonna just put the normal clutch in it. And their pull start was nothing but headaches as it would bend the recoil speing after a few pulls. 🤦🏻‍♂️
Looks like it was the studs that are backing out. Anyone have any ideas for them. Im gonna try to clean the threads real good and reapply red loctite.
Had a rollover on turf turning around… didnt think it was that bad til i seen a fin on the head got bent. All part of bashing.
