tizdaz
hi guys
ok a while ago i had a problem where my engine would stall then wouldnt start back up.
So oi decided to replace a few parts incl:
New 668 carb
New Fuel tank
New head gasket & piston ring
New Battery
to name a few..
then it seemed to be ok for the next couple of times i used my MB, then as most of you know i was close to giving up on largescale & was gunna sell my FG so didint use it for a good 5-6 months. Anyway last week took it to the track, no problems (but in saying this only had 2 or 3 runs & diditn even use a full tank up).
Today went out again to the track, 1st few runs was fine. would start up with no probs etc, then on my last run it stalled (the curse was fkin back!) ..tried to start it for ages...gave up!
Got home.. checked the fuel cap with the breather hole..all clear, taken spark plug out & tried a new one, still no go. With the spark plug out got some tissue and bunged it in the hole & pulled it over few times incase it was flooded & this is what i think the problem is, lots of unburnt fuel on tissue & strong smell of it?
So for the next 15-20 mins.. i just kept pulling the pull start as each time i could hear that the enging was trying to kick in more & more after each pull (a sure sign of flooding as it was getting rid of the unburnt fuel each pull so it was trying to start more & more), about 200 pulls later (literally!) it kicked in, so id say the problem is defo flooding, but why would it flood while the engine is running & cause it to stalll!? like i say was fine for a few runs then stalled due to flooding which is why it wouldnt start back up at the track.
So basically i need to know why the fker keeps flooding, if it was the carb settings then it would run like a bag of crap when it is running, but its been running great & just getting a little smoke form the pipe when i give it some throttle which is a good sign, so don't think its the carb settings?
ideas
New 668 carb
New Fuel tank
New Battery
to name a few..
ideas
