Lucien1986
- Reaction score
- 28
Check the connections they could be loose. I've had the same thing happen and i just wiggle the connections and it's good.When to charge my lipo 2s and got a connection break. Anyone knows what happened. Its been a while for me. So I think the cables are connected propely. The battery is new.
To be honest I never did that because they didnt tell me at the store. I charge it a few minutes in nimh 7 volt and then back to lipo and it worked. Saw it in YouTubeAre you trying to charge without plugging in the balance plug?
When pluggingTo be honest I never did that because they didnt tell me at the store. I charge it a few minutes in nimh 7 volt and then back to lipo and it worked. Saw it in YouTube
when I plug it in the balance Port is lt says cell voltage error.Respectfully..Lipos are nothing to fool with. Just ensure everything is good and watch to see how it responds...and really unless your using a new style Spektrum or Traxxas charger that can read cell voltage through the main plug...you need to have it plugged into a balance port and should be balancing the cells when charging.
Great input thnx buddyHmm, imagine that a smart battery that over discharged.... who would have guessed?
we(on this forum) had a conversation, not long ago, about how bad of an idea these smart batteries are. This is what I was trying to convey in the conversation. Over discharged and won't take a charge with standard lipo settings. Which shortened the life of the pack, and could have caused a catastrophic failure of the pack. The irony is, another member extolled how wonderful these features were and it wasn't possibly for this condition to happen with the smart battery. Now here we are. Here's my advice. Don't buy anymore "smart" batteries. Quite a few other options out there that won't lead to this situation.Great input thnx buddy
Plug in to balance board set for balance charge set for 2amps and it should work I have this battery.When to charge my lipo 2s and got a connection break. Anyone knows what happened. Its been a while for me. So I think the cables are connected propely. The battery is new.
Problem fixed with charging nimh and then back to lipo
