46u
Looks like Losi is getting in to the large scale seen.
http://losi.com/Products/Default.aspx?ProdID=LOSB0019BLKBD
30 pounds, aka 13.5kg would be right on the money.
5B's are around 12kg aren't they, and I presume the 5T's the odd kg or 2 more, and this is 4WD.
I always expect good things from Losi, and it's the main reason I still have one nitro - the 1/8 'Raminator' (modified of course but keeps the original 'look').
also bought some stainlees steel bearings,
good for 39000 rpm instead of 24000 on the stock bearing...
someone mentioned about diff bearings and hub bearings blowing up on the rampage xb so i have them on the side...or maybe ill just replaced them all now.
Ed
its 30 lbs.....
just punch in Losi 5ive T spec and youl get all the info.........
thats why i bought the Redcat xb...4x4...less than 20 lbs stock..30 cc..
steel gears ...exhaust...2.4 radio..around $500...
going to post some pics on one way bearings i instaled on the front axels.
Ed![]()
Kent at Killer RC was correct the 5ive T weighs ready to run with out fuel 37 pounds 2.5 ounces and I thought my 5b SS was heavy at just over 25 pounds. LOL. I know 4 wheel drive will be heaver just was not expecting 37 pounds.
That dosent seem right,my all aluminom nutech tb2 with zmc chassis ways 33 and my hurrax toxyc which is all aluminom tips the scale at 31,37 thats a lead weight.It's chassis looks hefty.
