losi 5t diff or removal.
dirby
Dothan Al
what is the best way to remove the rubber o ring from the drive cup inside the diff with out destroying the rubber o ring?
dougstar
KZN South Africa
Undo the diff . Inside you will find a pin holding the drive cup in. Remove the pin pull out the drive cup. Under the pin is a washer lift it up and uder there youll see the oring lift it out and there you have it(y)
dirby
Dothan Al
ok thx.pulling the drive cup out with the o ring attached will this damage the o ring/
dirby
Dothan Al
ok will have to give it a try.
just pull the drive cup out and the o ring will come off with out getting damaged right?
dirby
Dothan Al
going to change out some parts and up grade the diff fluds to a different weight.
thx Don.
thx for the help and info.
dirby
Dothan Al
link please.
I know what the diff looks like all apart only thing I am concerned about is getting the rubber o ring out with out damageing it.
bigdipperfred
somerset nj
Hi there.What diff fluid weight are you going to try out. Did 100k front 500k center 100k rear in my mtxl man what difference. But don't know what to use in the 5t .I'm not racing just bashing.
