so im itchy for a bigger (hp) engine...obr gives the option of methonal...whats the jury have to say about meth vs gas in these engines
You will use about double the amount of fuel you normally consume, cutting down your run times and you will go thru gas faster. The HP figures are with a pipe. Atleast the obr ones. Also , with methanol, it's a good idea to purge the engine after every run (if you aren't going to run it the next day), becuase methanol attracts moisture and moisture will corrode and fek up your engine. Aswell as, the methanol will destroy the diaphragms in ur carb if it sits. Few things to keep in mind. Personally I don't think it's worth it for just bashing. Drag Racing maybeThank Z.. since i consume maybe a gallon or less a month I think it would be worth my while for increased power...and when these engine guys give power numbers is this with or without a tuned pipe on it? Esp quoted 6 3/4hp for the race ported head...olimat has 2.95 stock and 4.34hp with pipe on a stock g320...i understand we're not putting a car on a dyno. I'm just trying to understand getting a base line to increase upon..from what i read on methonal it has lower energy density so i would assume the engine needs to be tweaked to push the fuel harder? Plus carst hat run on it get half the mpg so i can see more fuel is burned
Chop chop, better get your game face on mate. It's a lot of time to answer all these questions because you wont chime in?@SD73,
?, I was going to reply but saw he found the previous threads so I spared myself some time by not having to reply.?
I had a feeling you would reply thus also sparing me once again....????
Yep,especially after spending time writing it and about to post - when you beat me to it by .05. sec. ??Chop chop, better get your game face on mate. It's a lot of time to answer all these questions because you wont chime in?
You should have post anyway ? I wouldnt have been offended.Yep,especially after spending time writing it and about to post - when you beat me to it by .05. sec. ??
