MonsterAir
Lone Racer 🤠
- Long Island NY
Anyone have a picture of this kit installed or even better yet instructions?
Np ?Thank you very much Z. Wasn't sure if I was supposed to twist or not. The vids I seen on YT showed heavier wire so just wasn't sure. Again thanks for the help dude!
Can't complaint then ????don't let him fool you Z just likes to show his pipe when the time is right
This is very satisfying to watch. Thanks.
Yeah I mentioned that . Go get feisty on someone else. pretty sure I had ,had a couple of beers when I was doing this and had already donated a little blood to the 2 stroke gods . Got stuck by the damn wire. At least I didn't pinch my finger in the wiring pliers like the last time . That Fekking hurts.don't look at cops the one is wired wrong ?
The mod kit won't work with a big bore, because bigbores use m6 size screws for the header.looks like I’m going to need a set of these the 50gt in the vekta is kicking loose the header bolts. Twice in a week surprised don’t have this issue with my 65 supreme
I’m going to do what you said since I already have the long bolts so I will grab the nuts and wire. But I see Detroit sells a set isn’t this one for big boresThe mod kit won't work with a big bore, because bigbores use m6 size screws for the header.
So instead buy just m6 lockwire nuts, my studs, and lock wire.
You'll have to ask but I doubt it ,since it says it's made by mip (which is also MOD)I’m going to do what you said since I already have the long bolts so I will grab the nuts and wire. But I see Detroit sells a set isn’t this one for big boresView attachment 77393
