Mtxl dogbone pops out
Where are the droop screws on the lower arms? There’s only one position the lower shock mounts to. The top of the shock is mounted in the center hole.
Here where I have circled??
52932
So here is what to do??
Put y rig on a box/stand wheels off the ground ?? then adjust the droop so you can see that the dogbone is still making good contact/in the outdrive??
The screws in my rear arms are screwed quite far in already. I think they’ll come out of the other end.
The right rear one popped out, the cups look fine. No damage or wear on them. How much left right play movement should the dogbone have?
I am able to move the front dogbones about 2mm side to side. The rear ones slide about a centimetre or two. I’m wondering if is the wrong dogbones in the rear. Do you know what the dogbone lengths are for the front and rear?
I measured the rear dogbone and it’s 7” long
