My King Motor Baja does not have any sway bars. It is heavy at 36lbs and is quite stable for bashing. One of my favorites. The other one, a Rovan Limited Edition all aluminum has the same geometry as the KM but this also has sway bars. Thicker shocks and springs and will flip easy. It weighs about the same. I believe it is the difference in the shocks, springs and shock oil used. First thing I did with this one was flip it in the street just making a turn. one of those WTF? moments. I did try to loosen up the suspension as much as possible. As for the third one, most of the weight is the RCMAX/Taylor parts. The control arms are Rovan extended. I did opt for the sway bars on this. It sits much higher than the other two and have not rolled it over yet, that I recall. That one weighs around 38lbs. It is one of those assemblies you can step on and it will not bottom out in the rear end. Front, yah, that can be influenced to scrape bottom. The KM and Rovan can be compressed down so the chassis makes contact to the surface. Some of it can be balance from front to rear, as well as center of gravity. How much droop or squat you get under throttle in the rear end and lift on the front end may also factor in. As I said before, mine are heavy so that may contribute to lack of roll or may influence more pitch and tumble. I doubt any of them will reach insane speeds. I have learned to compensate for tight turns due to the understeer due to the mass of each vehicle, hit the brakes or drop throttle, start the turn and let it rip. Since this transfers the weight forward, there is more pressure on the front end to do the turn. The home built one with RCMAX parts will take the turn on three wheels. The front end tends to lift the other wheel under tight turns at full throttle. I have not noticed that with the other one that has shorter length arms and sway bars. The KM just remains compliant and does not seem to let go of the ground unless it has taken air due to terrain. I would say the KM feels sloppy and loose but works really good on off road conditions.
