My mcd body unfinished
Teejay112
Looking good dude. One thing Id suggest is taking a file to the wheel wells, and rear bumper around were a diffuser would be, the cuts look rough.
Yeah I should have done it before I started painting but I guess I'll leave that till last
Finished and added carbon fibre underneath the bumper also a pic of my max rpm with this rubbish exhaust I've lost 10000 rpm with this pipe
How much rpm did you loose? Not 10000 that's for damn sure. The max rpm for that engine is 16500 per their website. You may have gained a little bit with a good pipe but not 10k.
"Rovan 45cc 2-Stroke Gas 4-Bolt Engine designed to fit the Rovan LT, SLT, KM X2 and LOSI 5IVE-T
MPN: RV810221
NEW ROVAN SPORT (ROFUN) 1/5 Scale 45cc 2-Stroke Air Cooled 4-Bolt Engine (43mm bore, 31mm stroke)
  • Special HD Design Easy Pull Heavy Duty pull start system works great and has a nice big handle making this a pleasure to start
  • 8000 RPM clutch installed.
  • Walbro WT 1107 Carburetor
  • Very Powerful 45cc air cooled 4 bolt head, two stroke motor well over 4HP and tons of low end torque over smaller engines
  • 16500 MAX rpm
  • New style cylinder head.
  • Runs on High octane pump gas with 25/1 two stroke oil mix
  • Ready to bolt right in
  • Huge oversize exhaust port
  • Some exhaust systems mounting holes may need to be elongated to make fit on this engine
  • Some cutting/grinding of the rear chassis brace may be required for this to fit
Can fit many 1/5 Scale RC vehicles like HPI, LOSI, FG Rovan King Motor, Red-Cat etc... (Check out my other listings for one designed to fit the HPI Baja, Rovan and King Motor Buggies and Trucks 1/5 scale vehicles, part number 810221)"
