46u
I sure have my work cut out. Below is some of the parts for the 3 engines I will be working on. All the parts below are new. I all so have other new parts like pull starters, coils and so on. The first one is a race ported DDM GP290 top end. I will be using the DS templates to help as well as opening the ports up matching the cases and cylinder. TFE bearings ADA billet intake manifold and 813 carb,
I just received my ONB ported and machined for the plus 2mm (30mm) crank 30.5 kit. Great service from these guys!!!!! Ordered the kit Friday and it came in today. I live clear on the other side of the country from them. Even thaw there porting is more radical then the DDM GP290 race ported kit I will still have quite a bit of work to do as far as matching the cylinder with the case. At first check it will be as much as the DDM ported GP290 Kit. I will all so be getting a ADA billet intake for it and a 813 carb. On top of the cylinder they have .022 so I am guessing that is the squish they have the cylinder machined for. I will check this when time comes like I will on all my engines.
Then I have a totally stock 34mm 26cc with stock stroke that will be the one I try a total port job on my self after some practice. If I get another bottom end at a good price I will all so build it as complete engine. If not I will try the cylinder on my stock 26CC in my 5b SS right now.
What are peoples opinion on cutting the piston skirt on the intake side? Any information would be great.
I hope to start doing some practicing on my test cylinders this week. The ones people sent me that have plating problems and are use.
I am hoping to get a degree wheel either this week or next as I want to degree the GP290 and the ONB 30.5 before assembling and all so will need it when I port the stock 34mm I have.
