Problem starting 5T
MrRed
New Member
Hello, got a used 5t a month ago ran great now problems. I changed plug, new air filter and new fuel filter. Now I got fuel coming out the air filter. Any thoughts?
Didn’t put carb on backwards. Took carb apart last time out. The screen in bottom was packed with sand. It ran ok for the rest of playtime. Wondering if I need a new carb
If you got sand into the carb your clunk is either shot or not there, the fuels coming out of the venturi is a bit odd, I must admit I've not had that issue my self..... I would check your clunk (in tank) . make sure you don't have your lines on backwards on the carb as it will run depending on how far down the return sticks in the tank, and would explain how sand got sucked up into the carb.
