- Long Island, ny
- Thread starter
- #581
I guess I had a second account...
I logged into the wrong accountTf was that about ?
crusty crack ?Is this a crack on the housing
Hey now we are talking about misterleon here, not you ?crusty crack ?
?Hey now we are talking about misterleon here, not you ?
Much Larger Bearing to help with extreme load. Lasts much longer then standard flanged bearing. This equates to less maintenance cost over time.
Improved Geometry, as now its less likely to strip gears as the OEM right side diff insert is undersized and allows diff to move fore and aft in the case causing improper pinion / ring gear diff engagement which can cause failure to occur.
Improved clearance to run boots over the outdrives. This will help refrain from bone and outdrive wear.
Been in Matts Cars for over 3 years, with success after success with less maintenance cost over time
MOD INSURANCE POLICY:
Ultimate MOD Rear Diff Inserts $63.99 > $64.98 Replacement Ring & Pinion (not counting countless bearings you wont have to replace and have to empty your diff oil continuously to reach the left hand bearing ($27.98 on average to rebuild bearings/oil) (View second image for parts breakdown)
FEATURES:
7075-T6 Anodized Aluminum
Avid RC Bearings
100% Made in the USA!
That’s way cheaper than a rcmax diff housingI had that on the 5b? I did the mod oversized bearing upgrade by MOD problem solved ?? the diffs all have the same bearings from stock and they are pathetic ??
Yeah. Took about a month for them to ship my top end rebuildso I will have to wait another week or 2 for the top end rebuild from obr. maybe it is time for them to start expanding operations to keep up with demand. I love their product and their costumer service but month+ lead times are a bit much.
I mean I get it they are busy and they should be they are a great company but surely they can hire an extra couple of guys to help expedite orders. to be fair I don't know what kind of margins they are working with, it may not be an optionYeah. Took about a month for them to ship my top end rebuild
Is it the Sig Series or full mod top end? If so they have to port the top end before sending it out. Its not about grabbing it off the shelf, packing and shipping. Gotta stand in line like the rest?I mean I get it they are busy and they should be they are a great company but surely they can hire an extra couple of guys to help expedite orders. to be fair I don't know what kind of margins they are working with, it may not be an option
