RcJunkie TLR 5b
Alright, so I just wanted to address this, killswitches are compatible with spectrum radios. You need to push the button you use (along with the brakes) when binding, this way the rx sees the killswich as a form of failsafe. Imma pick up a bottle of dominator tmrw and might do the first heat cycle (not a word ?).
Starting off the new year with a new TLR 5b ??
Im in the middle of building mine now ??
Uggghhh, now the rear diff is binding a little and I cant see anything wrong
U can take the little washer off the rear pinion then put it outside the case in between the bearing and the coupler that way the it wont move. Should get a smooth mesh. Thats what i didimage.jpg
I actually used 2 the 1 small one it comes and a m.o.d steel diff kit bushing ?
First and second heat cycles done today, I might finish the break in later the week, supposed to be ~60 here in NY. Here’s a vid, the Rovan pipe sounds WAY meaner than expected, doesn’t sound it on camera tho.
Can you guys see the vid?
