- Reaction score
- 27,691
I can see the vidoe, Sean is just being a twat ?
Wdym “glazing”?start the glazing process
Look up cylinder glazing.Lol, figured so ??, but I can’t see it on my phone (which is the case for most on this forum) so I wasn’t sure
Wdym “glazing”?
I was being a peepee, but I also couldnt see it last night. Idk what's up, can see it this morning.I can see the vidoe, Sean is just being a twat ??
If the pipe can move it isn't tight enough, I've slotted exhaust already amd never had leak or movement issues. You gasket wasnt sealing, so either the pipe flange isnt flat, the exhaust flange isnt flat, the bolts weren't tight, or the gasket blew out. Can see the gasket didnt blow out, I assume the bolts were tight enough, so has to be something not flat for it to leak like that.Ok guys do you think the leak could be because the holes are bigger then the bolts, allowing the pipe to move and create a leak?
jus buy a bartolone already![]()
+1??If the pipe can move it isn't tight enough
Idk is the stu would for sure, but I'm fairly positive the tr box would sneak through in there, it hugs the side if the engine pretty good.Will the crazy stu go on?, and yeah I have though about the TR box (almost bought it), I will need to have it stick out the body. Ill see how this works out first
Side profile
That looks realy nice they did a good job on the paint.Finally a pic with the body on, air filter is a really tight squeeze, had to squish it.
