Red Scorpion , project.
I 'm back and I'm happy.
Bigger the Better : It is a homemade chassis for a homemade rc car .
sperera : It is not a 'baja' becouse of 4wd , and suspension system ,brakes....
Al : I think that we could see it 80% complete , next two weeks.
Most of parts are semi-ready to use .
Thank all of you , mates.
Jackobyte :
'' How do you get on with the Carb angle, does it fill ok due to its horizonal position.''
I'm sorry but I cannt understant it.
Just a thought !!
Hi Vass,
There's a thread somewhere where one guy has noticed that the rear sprocket / gear of the 4WD FG has more teeth than the front. I suggested that this may be to counter an understeer effect, balancing it out, and possible pulling the truck around.
I was wondering if you've done the same, or you've the same gearing front and rear?
Hi Vass,
Good call Al.
J.
Hi Vass,
Hi Al ,
I use the same gearing front and rear.
Maybe they use central diff and the system works. In my car , without central diff I think that it is wrong , or not ?
Vass
